[quote=“Radjin, post:1, topic:174821”]I used this to set things up: GE Concord Alarm Panels
One device shows up: Caddx NX584 Security System with no errors.
I am using a concord 4 panel with the superbus 2000 automation module that was running the ADT Pulse system.[/quote]
GE Concord is not the same panel as GE Caddx. Uninstall the Caddx plugin and install the Concord one. (And start a new thread if you hit any problems.)
[quote=“futzle, post:2, topic:174821”][quote=“Radjin, post:1, topic:174821”]I used this to set things up: GE Concord Alarm Panels
GE Concord is not the same panel as GE Caddx. Uninstall the Caddx plugin and install the Concord one. (And start a new thread if you hit any problems.)[/quote]
I appreciate your quick reply, however according to Julian Minut of the MiCasaVerde support team that was the app I should be using. Obviously she was wrong. However, I see no app listed for the Concord 4 system under the “install apps” tab when logged into my vera 3. Can you point me in the right direction.
