GE Concord Alarm Integration Alternatives
I have a GE Concord Alarm and would like to connect my Vera Plus to it. I have tried buying the Superbus 2000 Automation module (60-783-02) but I can?t find anyone that stocks them. Four out of four resellers are claiming at least a 3-4 week wait to get one.
Is there another way to connect Vera Plus to this alarm panel?
Hello,
As you can see here:
http://code.mios.com/trac/mios_ge-concord
you’ll need to have the SuperBus 2000 Automation Module. Without that piece of equipment, you’ll not be able to integrate the system alarm with our controllers.
Thank you and Have a nice day
Amazon has them in stock GE Security 60-783-02 SuperBus 2000 RS-232 Automation Module https://www.amazon.com/dp/B0028PU6LI/ref=cm_sw_r_cp_tai_vhTpCbXZNA828
Bought one here. In stock and prompt delivery https://www.homesecuritystore.com/ge-interlogix-60-783-02
Ordered my Superbus 2000 AM from here (great price although 4 weeks to get it):
https://www.123securityproducts.com/60-783-02.html
I’ve got it all hooked up and all that’s left is figuring out how to set it up.
Hi! Im certainly not an expert in any of this, and I have been following the link - http://code.mios.com/trac/mios_ge-concord - so all good on the hardware side, I am running UI7 - when I go to install the plugin I cannot find a GE concord plugin. Is this still available or should I be using something else?
Read through this link. It gives you everything you need to know about installing the plugin http://forum.micasaverde.com/index.php?topic=49393.0
Thank you, got it to work great - I appreciated the help.
Good luck with your setup. It’s a solid plugin and gave me good service on the Vera Edge.
