I don’t know if I’m doing this wrong, but In the instruction to wire this device I brought on amazon.
GE 45612 Z-Wave Wireless Lighting Control In-Wall Dimmer
The device do not have a neutral wire (white). I have wired the GE 45609 and that one does have a neutral wire and I have power to the device because the blue LED lid up. Now when I wire the 45612 without the neutral wire, there is no power to it. the blue LED doesn’t lid up. So I know there is no power to it.
Question is anyone have the GE 45612 and only use the line, load and ground wire to get it working? I also tried adding the auxillary device 45610 to it with the terminal to the 45610 and on that there is a WHITE(nuetral).
But that didn’t work either. Does this device work without a neutral can someone shred some light here. Or is there another brand of dimmer that have the nuetral wire?
