GE 45605 Dupelx Receptacle
OK, I am a newbie to all of this, so shoot me if I am in the wrong place. :o
Anyone try one of these (GE 45605 Dupelx Receptacle)? I picked one up at The Hack (Radio Shack) this weekend. Initally it setup and worked fine, but is seems that after some time, it stops working correctly. The logs show Failed - Cannot send command to node. It will on occasion, in between all of the failures, show Successful - Successfully polled node.
If I reset Vera, it starts working again correctly for a while
If I remove/delete the device and add it back in, it works again.
I have moved Vera to see if that makes any difference (maybe it has some problem communicating, but my house is not that big).
Any thoughts?
Update:
After moving vera to a more central location and rebooting, the problem seems to have gone away. If anything changes, I will update here.
