I am able to add the remote in Veralite UI and pair it as described in the wiki document by putting the device in receive mode, however I am not able to add scenes.
When I try to re-pair the device it says scene transfer failed or something like that (it shows up only for a short time).
I also don’t know how to enable the Thermostat button on the remote to work with my ZTS-110 thermostat.
I am using a Veralite G with official firmware 1.6.641 and UI6.
You might very well be the first person to try pairing and adding scenes to the 45601 under UI6. I would suggest that you turn on verbose logging, try the process again, and then submit a trouble ticket (with full access enabled). Vera Support can look at your logs and get an idea of what is going wrong.
