I have had my Vera 3 for over a year now and have just set it up as a pretty basic system. This year I figured I would try some enhancements and so I added my Foscam cameras to the system, as well as some dry contact devices to open and close my garage doors. I also wanted to add some handy remote controls that I could scatter about the house so as to turn lights and fans on easily.
So I bought a couple of GE 45600 remotes (can?t beat the price) and a GE 45601 (just to play with). I am using them strictly as a secondary device to my Vera 3 and only to control scenes. So after reading many posts on these devices, I did figure out how to include the remote into my system. Pretty easy, hit the include on the Vera and do a setup, 967 on the remote. Then add the scenes to Vera for the devices I want to control, and then set triggers for those scenes that correspond to the button I want on the remote. Pair the remote to the Vera once again, I cal this the 967 procedure and bang, done. All pretty straight forward. Then the quirks started to appear.
It seems that not all devices can be controlled with the OFF button on the remote. No problems with my 45609 on off switches that I use for fluorescents and fans. Also no problems with the 45612 wall dimmers, the 45614 3 way switches, or the Remotec Zwave Dry Contact Fixture Module which I use for my garage door opener. But the GE 45602 plug in lamp module will not turn off using the off button on the remote.
I also have a few Kwick set zwave enabled door locks in my system. So I thought it would be cool to set a button on the remote to lock and unlock the certain doors. The lock part works OK but you would think, just like a light switch, if you hit the off button, it should unlock. But no luck there either. And one more quirk is that these same devices that do not accept the off button, also will not program on the higher number buttons, or what you might call the shifted buttons. I can not even get them to work for the on part of the device. So door locks and lamp modules can not have a button number of 10 ? 18. The scene I have set up in Vera works fine, but the remote will not trigger that scene with a button number of 10 ? 18.
I even went as far as putting a few devices in that scene that do work, such as one of the 45609 switches. The 45609 does activate with a shift 1 button press, but the 4562 lamp module does not. Now you would think a scene is a scene and it doesn?t matter what devices are in the scene, you simply are triggering the scene with the remote, but some devices in the scene will not trigger on the higher button numbers.
The next quirk, and this has also been discussed in other threads, but I have not seen any resolve for this, is that some buttons on the remote will trigger scenes associated with other buttons. On both of my remotes hitting 4 will also trigger what is triggered by 2. 5 also triggers 9, and 7 also triggers 8. Now in other discussions, these have been described as well but with different mapping issues. Someone had said it was an issue with the remote sending duplicate instructions to Vera, another person attributed it to Vera not processing the information from the remote correctly. Yet I have not seen any advice from tech support on this issue.
I do have a secondary building, a guest house, that I also set up a Vera 3 in. After some issues, I did get it bridged to my Vera 3 in my main house. All of the devices from the guest house show up on my main Vera system no problems. But again wanting to control some of the lights, especially the outside lights around the guest house from the main house, I figured I would set up some scenes and associate them with a button on my remotes. Again I found that only the on button works, not the off buttons, and before anyone comments, yes I did pair the remote to the Vera, the 967 procedure, after setting up the scenes and triggers. Now these scenes are controlling devices that did work with the off button in my main house, primarily GE 45609 switches. And again like the other devices that will not work on the off button, these scenes can not be programmed onto the upper number or shifted buttons either. So bottom line, scenes associated to bridged devices act in the same way as the lamp module device, no off button and can not associate with a shift button.
So after reading this if anyone can confirm some or all of my findings, or more importantly if someone has found a work around or solution to any of these issues, please tell.
As an after thought, I never did get “when a scene is de-activated” to do anything, thinking that it should program the off button on the remote. the off button only seems to associate with turning devices off from a scene that was programmed with the on button, and again only for those devices that I mentioned above.
