Hi there,
I spent hours yesterday trying to install the GE 3-way on/off switch and it’s still not working properly. The wiring of my previous 3-way switch seems to be a bit different from normal. Here’s how it was originally configured (please excuse my lack of proper terminology, I’m not that familiar with wiring):
SWITCH 1:
3 power lines (A,B,C) with 2 wires + bare (white, black)
1 power line (D) with 3 wires + bare (white, red, black)
SWITCH 2:
1 power line (E) with 3 wires + bare (white, red, black)
In switch 1, all bare wires were connected to a wire nut. The neutral white wires from A, B and C were all connected via a wire nut. The neutral wire from D was connected to the top terminal of the switch. The black wires from A and B were connected via wire nut and a jumper to the middle terminal of the switch. The black wire from C was connected to the red wire from D via a wire nut. Finally, the black wire from D was connected to the bottom terminal (black screw) of the switch.
In switch 2 the bare wire was disconnected. The white wire from E was connected to the bottom terminal (black screw) of the switch. The red wire was connected to the middle terminal of the switch, and the black wire was connected to the top terminal of the switch.
After some trial and error I configured the 45609 as follows:
Black wires from A, B and D connected via wire nut and jumper to LINE. Black wire from C connected to LOAD. White wires from A, B, C and D connected via wire nut and jumper to NEUTRAL. Ground wires from A, B, C and D connected via wire nut and jumper to GROUND. Red wire from D connected to TRAVELER.
This works beautifully - the LED lights up, the 45609 controls the light on/off without issue, and surrounding electrical outlets seem to operate just fine - but the AUX switch is useless and does nothing.
The 45610 I configured like so:
White wire in switch 2 to NEUTRAL. Ground wire to GROUND. Red wire to TRAVELER. Black wire capped.
Both the black wire and red wire are hot, regardless of the state of the switch on the other end.
I’d really appreciate any advice on how to configure this correctly - it’s not at all like the instructions in the book and I’ve researched many posts on this forum without encountering this same sort of scenario.
