GE 170 Z-Wave Wireless Lighting Control Duplex Receptacle
I have been trying to pair this light switch and have been unsuccessful. I have tried to bring Vera to the switch and let Vera plugged in using the add a device option in UI5. The darn thing will not be detected by Vera.
Is there any other way to get it added? Vera 2 running UI5.
Light switch is GE
170
Have you tried doing an exclusion of the device first before the inclusion?
  • Garrett
I believe I have. What I did was I use the wizard to add a device and then told it that the light wasn’t fluttering fast so Vera attempted to remove it but nothing happens. Is that what you referred to as excluding the device?
Ok I got it to pair by excluding and including a bunch of times. However now I get the error: device failed to configure. When I click configure mode right now I get the message unable to get any information on node.
Changing the configured field from -3 to 0 doesn’t help either.
