Gathering all info before a complete reset?
Hi, my Vera is unhappy and after months trying to get it working right with tech support i am almost ready to factory reset and rebuild it from scratch. Can anyone recommend the best way to get a file(s) with all my Luup code, triggers, schedules, scene actions, device settings, virtual devices, apps, etc. out of my vera (via scp is fine if i knew which files to grab) before i reset it – so i can make sure i do not forget to rebuild any of the logic? Thanks!
Do a Z-Wave backup.
Then do a regular backup.
Then you can reset.
Then do a restore with restore Z-Wave backup option.
Thanks, i did try that already. I need to try a rebuild (not a restore) from scratch.
It is a hail mary, MCV tech support has not been able to figure out why i get unix (not just luup) restarts when trying to heal, my leviton controller works properly only some of the time, half my HSM’s don’t un-trip (and had to be added manually by tech support as vera would not recognize them other than an Generic I/O), my lock periodically fails to communicate (10 feet from Vera), etc.
This would be the same process to move to a new Vera.
Just replace the reset … with move to a new Vera.
So do what ever you want for a reset …
Hopefully the problem is not with the code that is restored!
so if the problem is in the z wave + Vera then would this work in theory:
  1. zwave network backup
  2. Backup
  3. Exclude all z wave devices
  4. Reset z wave network
  5. Include all z wave devices from scratch healing periodically to see if healing starts causing unix reboots again and I can isolate the cause
  6. Redo associations (eg for aux switches)
  7. Fix all code and scene references to use new device ids
  8. Heal several times
to make sure I do #5 fully it would be great to be able to have a file showing all device associations and devices used in scenes so i don’t have to remember.
And if that does not work and I need to also factory reset it would also be really helpful to have the rest of the information at hand.
Thanks for all suggestions and help !
As long as you keep the backup from the first step 2 …
You should be able to get back to where you are today … Maybe not a good place … but a known place.
Sorry I do mot know of a way to get a nice report of everything you have so you can make sure you rebuild properly.
A lot of the configuration info is in the data from:
http://Your.Vera.IP.Address:3480/data_request?id=user_data
This file is part of the backup. But You need to know how to interpret it.
If you get to step 7 … and things are still flaky … You will need a new Vera … Then the backup will get you going quickly.
@mda
The new eventwatcher plugin might be able to help as it can list the details of your scenes
Also when doing the Vera backup you might want to try doing a test restore before you do the full reset as I’ve seen it mentioned many times on this forum that the backup can be corrupt and would not work.
This way you can test you have a good one before you wipe everything.
thanks guys. i will give all the above a try if i have to rebuild.
