Can someone tell me how to hook up the Linear FS20Z-1? I’m not an electrician and the diagram in the instructions doesn’t make sense to me. The wall switch I have is a low voltage relay switch so two wires for the power and a ground. What do I hook up where? There’s no “Neutral” but I thought that was the point of buying the Linear??
I don’t think it is that complicated. You should have 4 wires. (5 with the ground)
2 to power the switch (line Z(black) and neutral (white)+ground (green) to wire into a power outlet.
2 for the dry contact switch which you need to put in line with your low voltage circuit to power the fireplace taking the place of your current switch. (Blue)
Use the dry contact diagram.
Thanx for the reply!
If there was a “Neutral” then this wouldn’t be a problem. But there’s isn’t a neutral, just the two wires for the switch and the ground…
You will need to install this on the Fireplace side … where you have access to POWER.
OR
If there is a power outlet in the wall below the switch … you may be able to fish a wire from it to this switch to provide the needed power.
[quote=“f30er, post:3, topic:189990”]Thanx for the reply!
If there was a “Neutral” then this wouldn’t be a problem. But there’s isn’t a neutral, just the two wires for the switch and the ground…[/quote]
The switch itself needs to be powered so indeed you need to run not just a neutral but also a line to it. I created a cable which I plugged into an outlet under my fireplace by cutting a computer cable and wiring it to the switch.
