I haven’t found a thread with photos of how other people mounted their garage door sensors. I posted mine up over a year ago, but they’ve long since expired. The last time I used woodsby’s garage door plugin, I formed a piece of 2x4 to the top of the door to isolate the sensor from the aluminum. The doors I have in my new place are hollow-core & I don’t have easy access for fixing a wooden “bracket” like last time.
I just tried this with little hope that it would work, but it did. No brackets, just double-sided tape. I really thought the proximity to the aluminum was going to throw everything off, but it’s working great:
Mine are similar to your pictures. I tried that way first due to laziness and, as you said, it worked.
In the very beginning the door track would scrape the magnet off the door, but some filing and epoxy glue(lower profile) rather than foam tape solved that. I also made a special effort to mount the sensor at the far edge of the magnetic field so that if the door moves even a few millimeters it trips the sensor.
However, the best way is definitely something like the Seco-Larm Garage Door Contact. It allows reliable mounting and the ability to place the Z-Wave sensor almost anywhere, should the metal door present a signal problem.
I remember looking into these a few years ago, but I haven’t had the need to do it yet… though it would have been a cleaner solution than my wooden “bracket.”
[quote=“DeltaNu1142, post:1, topic:177435”]I haven’t found a thread with photos of how other people mounted their garage door sensors. I posted mine up over a year ago, but they’ve long since expired. The last time I used woodsby’s garage door plugin, I formed a piece of 2x4 to the top of the door to isolate the sensor from the aluminum. The doors I have in my new place are hollow-core & I don’t have easy access for fixing a wooden “bracket” like last time.
How have others gotten around this?[/quote]
I don’t know if this is the best way to do it, but this is what I did.
I attached 2 pictures of how it looks when done. Basically, I went to the plumbing section of Home Depot and got 2 thin metal strips approximately 12" x 1.5" (39 cents each) and bent them as shown in the pictures. The top of my two garage doors have metal brackets that I attached my strips to with a nut and bolt. I used the included double-sided tape that came with the Schlage door sensors and stuck the magnet to the end of my strip. I put the sensor unit on a ledge above the door. If I didn’t have the ledge I would have probably just mounted it with tape or the included screws.
I’m using a MIMOlite to actuate the doors and the Garage Plugin to tie the two together. The plugin is very simple to set up. Just add the deviceID of the door sensor and the MIMOlite to the plugin and you’re good to go. The door sensors are away from any metal and have a nice clean line-of-sight to the MIMOlite or any other ZWave devices you might need if you’re not close enough to your Vera controller.
