My Chamberlain doesn’t have a simple closed contact input for door open & close functionality. Since Chamberlain doesn’t offer an open API for their web control products I suppose the only option is to wire a relay that bypasses the push button on either the main garage wall box or 1 of my car openers.
Has anybody come across any product that will make attaching wire from my relay to the circuit board easy?
I was wondering if something exists like a circuit probe w/ hook which can be attached to the small push button leads on the board. They’d have to be very small and thin hooks though. For anybody that has done installs like this I’d be happy to hear what you did and how well it worked. I’m not a fan of soldering but I will do it if it’s the best option. I’ve got a soldering iron but I’m not very good with it.
Check out the Liftmaster 829LM. It’s MyQ compatible and might be able to provide a way to close garage doors. It doesn’t offer support for open but can close up to four doors.
Thanks, but I’m wanting to have all of my house controls in one app. I’d rather stay away from having to use the MyQ app. I’m thinking I’ll just solder it. I’ll probably just attempt on my extra car opener. If I fry the board, they’re cheap enough, I’ll just buy a new one.
You don’t actually need to solder anything. Just use a relay module and wire it to the contacts where your push button gets wired too.
Something like the Evolve Guest Controls LFM-20 RF Controlled Z-Wave Isolated Contact Fixture Module would work for you, its what I have currently and I use iVera mostly to control my stuff from my iPhone. There’s also a plugin for Garage doors that works with it and a contact sensor that makes things very easy and nice.
An alternative might be a MIMOlite, and the “Garage Door” app.
You wire the door contact to this device. Then wire this device to the Opener’s terminals. Power it from the outlet above the ceiling where the opener is being powered. You get open, close, and state this way.
Thanks for the input everyone. Just an FYI for anyone that has a Liftmaster opener. Even though their factory switch has 3 buttons done over a 2 wire interface (door, lights, …I forget what the 3rd button does…) you can replace that with or add a simple momentary switch/ relay in parallel. That will do open/close commands.
Hi, I have a Chamberlain GDO with a WIRELESS push button…where do I connect the relay to?
I’ve tried connecting it to the terminals in the GDO for the wired button but although I hear the relay ‘click’ on and off there is no action by the GDO.
