Garage Door Issues...(SOLVED v2501+)
Anyone else running into this issue?
I have a Linear GD00Z Garage Door trigger and am running latest UI7 (v17513) with IH 2424.
Looking at my system through a desktop browser UI, I see the garage door represented correctly.
In IH looking at the widget for the garage door, I see the stock light bulb ON as it should be for the garage door. Eve if I switch the icon to a security icon, with the lock image, it works correctly.
Here is what is wrong.
I wanted to change the stock light bulb to the new garage door icon, so if you do this, it shows the garage door opposite of the true state of the garage door. So when my garage door is open is shows closed in IH UI.
Anyone else getting this? How to fix?
[quote=“Jamr, post:1, topic:185883”]Anyone else running into this issue?
Anyone else getting this? How to fix?[/quote]
Image works for me, but I’m still on U15.
This is happening to me as well. Garage is closed, the icon shows open showing the car. Garage is open, icon shows closed with flashing red background.
Imperihome new versions now have a tick box when selecting a state icon to invert. Tick that to reverse the icon so it shows correctly.
Long hold on the icon, go to configuration, then “Change Icon”, then check the box “invert icons (for dynamic icons)” in lower left corner.
I feel like an idiot. I don’t have that option. I can’t find it anywhere. Tried looking in:
Long hold widget/icon - > configuration (see attached picture)
Or Long hold widget/icon → configuration → Long hold the icon I want to select: nothing
My bad, I forgot a step. I corrected the above steps. If you still do not see it, what version are you running?
2.5.0
[quote=“jjwalker, post:6, topic:185883”]I feel like an idiot. I don’t have that option. I can’t find it anywhere. Tried looking in:
Or Long hold widget/icon → configuration → Long hold the icon I want to select: nothing[/quote]
You still need to tap on “Change icon”. Then it will show you a check box that says "Invert icons (for dynamic icons).
[quote=“tomtcom, post:9, topic:185883”][quote=“jjwalker, post:6, topic:185883”]I feel like an idiot. I don’t have that option. I can’t find it anywhere. Tried looking in:
You still need to tap on “Change icon”. Then it will show you a check box that says "Invert icons (for dynamic icons).[/quote]
I do not know if he has it in v25
Oh…then get the update. I thought that was released to the app store already although I use the beta channel I thought that version had it.
I don’t know it might. It sounds like he can’t find it in 2.5. I just noticed it in my version (2501)
The app store currently has 2.5 for the free version and 2.0 for the pro version.
The app store currently has 2.5 for the free version and 2.0 for the pro version.[/quote]
Hmm…my bad. I really thought the last public release had it. Well I would highly suggest to join ImperiHome’s beta Google+ channel. I’m on B255 and they are responsive in posting. In fact I emailed the guy about getting options to invert the icons because some prefer the opposite state of the icon.
Yeah that option isn’t in my version. I’ll check out the Google+ channel.
