Hi ![]()
I’ve searched a way to change some value of my variable containers from my phone, and the only one i’ve found is to send an http request with tasker (handling the fwd primary/secondary server and the local/remote connaxion). It’s a bit heavy to handle in the tasker tasks, it takes time, it’s not friendly.
I’ve looked at the vera3 enabled application on the play store (for my 2.3.6 android phone) and AutHomation is the only one to handle the device by clean intents.
Is it possible to add on your todo list an intent syntax for the variable container ? I’m dreaming about a “authomation://device/VeraID/deviceID/variableID/[value]” intent to send a luup.variable_set(“urn:upnp-org:serviceId:VContainer1”, variableID, value, deviceID)
Thanks anyway for this good app, even if I can’t test the HD version.
