trying to use a kwikset lock with Vera1, from which vera firmware rev are lock supported ?
is wl500gP_Luup_ui4-1.1.1062-1.trx suppose to work with Kwikset deadbolt ?
V
V
What release are you wanting to stick with UI2, UI3 or UI4. With UI4, the locks are supported. Not sure if it goes for UI2.
OK, thanks I’m using UI4 and you say it supports locks - that’s what I needed to know.
I’m trying to sort oout issues with my attempt to flash an actual ASUS router
http://forum.mios.com/index.php?topic=7374.0
Vincent
