I had a long period of stability with my Vera. A few weeks ago, I started noticing issues and started keeping an eye on the System Monitor plugin. It was showing that I’m having frequent Luup restarts. I haven’t changed anything before the issues began: I was happy to let a stable Vera do its thing.
I checked in with MCV and they suspected that it’s a PLEG issue and said (after one check):
Something about this PLEG condition is crashing the unit. You can try to delete it or edit it to stop it from flooding with requests as it?s generating memory leaks and eventually crash the engine.
I know to take this with a grain of salt, so I’m trying to figure out the best way to debug things.
I guess that the first issue is figuring out how to view the log without leaving the “Log for LuaUPnP” window open to the log all the time, then hunt for the error. I know how to SSH to my Vera, but I’m not familiar with tail/less/more to know the best way to view the pertinent section of my log to see what was happening.
Can someone get me started on the road back to stability? I suppose the first thing I need to be able to do is browse the LuaUPnP log for whatever happened just before a restart.
