I created a new plugin to control the Freebox Revolution ADSL box.
As this box is used by French users only (the box is provided by the French ADSL provider named “Free”), the main discussion will be followed here: TouteLaDomotique.com : la maison connectée au meilleur prix
Can an administrator create a new entry in code.mios.com and give me the access right ?
Ajout activation/d?sactivation AirMedia (interface graphique + actions “ActiverAirMedia” et “DesactiverAirMedia”)
Contr?le du AirMedia dans une sc?ne gr?ce aux actions “LancerAirMedia” et “StopperAirMedia”
Ajout de la fonction Text To Speech via le AirMedia (onglet TTS de l’interface graphique + action “Dire”)
Ajout activation/d?sactivation UPnP AV (interface graphique + actions “ActiverUPnPAV” et “DesactiverUPnPAV”)
Possibilit? de piloter deux Freebox Players (interface graphique + nouveaux param?tres “Player” et “Telecommande” de l’action “CommanderPlayer”)
Sauvevarde du player et de la t?l?commande par d?faut (onglet Player de l’interface graphique + nouveau param?tre “Player” de l’action “DefinirTelecommande”)
V?rification de la permission de modifier la configuration du Freebox server avant de lancer une commande de modification
Optimisation de la gestion des 2 cycles de rafraichissement des donn?es (configuration/p?riph?riques r?seau d’un c?t? et appels t?l?phoniques de l’autre)
Am?lioration de la gestion des logs (variable DebugLogs)
Hello I have recently noticed that the buttons on the settings page for this plugin was not working any.
many http requests made by the plugin to the vera were failing with a http 404 code
it turns out the plugin was written to use the “command_url” which is using the “/port_49451” url.
This now fails and I suspect a recent firmware may have changed what is accepted on this kind of url
I am wondering if the proper way should not have been to use the “data_request_url” and therefore I made the following change to the v1.0 of the J_Freebox.js
OLD line 861
new Ajax.Request (command_url+‘/data_request’, {
NEW line 861
new Ajax.Request (data_request_url, {
it seems to work…
Question for MCV : the author of the plugin is not working on it anymore. can someone take the fix and update the MCV app store ?
