I’m not sure if this is specific to the fact that I use the Radio Thermostat Wi-Fi plugin for my thermostat or if it is a general thermostat issue, but for the tile I only get a “?” on the thermostat. I was wondering if it were possible to at least show the current temp. If possible, it would be nice to actually be able to adjust the temp, but I understand that at least for this plugin, there is a different temp for “cool” vs “heat”.
Note that when I click on the tile, I can actually adjust it just fine.
** This is using the newest Alpha I believe (3.2.1.4)
