Foscam IP Camera Plugin
Hi Chris –
That was my experience also. The motion sensor does not install for the FI9821s. I have tried various alternatives with no luck.
 Don
[quote=“Chris H., post:196, topic:171931”]I added 2 9821w camera’s to my system last night and tried to add the to Vera with no luck. I noticed the Foscam Plugin is now the “Vistacam PT&HD IP Cameras” Plugin.
I uninstalled my old plugin and also uninstalled all my cameras and manually added them based on this thread. My 8910w’s setup fine and the corresponding motion sensors but I am unable to get the Motion Sensors to install for the new 9821w’s. One of the camera’s sits at “Configuring” on the dashboard with the blue circle when I change “Configured” from “0” to “2” but the second camera doesn’t even have the Variable “Configured”. Anyone have any idea’s on what’s going on and how to fix it?[/quote]
Thanks Brientim, perfect :slight_smile:
Hello !
I can see in apps.mios a newest version (2013-05-20 05:35:49) for vistacam plugin.
it is for foscam too. Plugin for the VistaCam PT, VistaCam HD and Foscam (non-HD + HD) cameras
I have installed my 4th foscam camera but the motion sensor and presets do not works and I can not record pictures as well.
is this plugin a best option to do the things works ?
or foscam plugin will be updated to correct this problems ?
thanks…
Vera3 : current firmware. F19821W with latest firmware.
I think I have followed the advice here but cannot even get the snapshot working for my F19821.
I can use the url http://192.168.0.100:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture&usr=admin&pwd=xxx from a browser to get the snapshot and url http://192.168.0.100:88/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=admin&pwd=xxx to get the stream.
In my Vera device I have : Device Type : urn:schemas-upnp-org:device:DigitalSecurityCamera:1
                              IP                   : 192.168.0.100:88
                              Device File      : D_DigitalSecurityCamera1.xml
                              Impl file          : I_Foscam98HD.xml
                              Direct Stream : /cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=admin&pwd=xxx
                              Url                  : /cgi-bin/CGIProxy.fcgi?cmd=snapPicture&usr=admin&pwd=xxx
                              User               :
                             Password        :
I have pretty much tried all the variations of the user / password / direct stream / url values.
The camera has been set to low resolution for the snapshot.
Any ideas?
my informations are:
IP : 192.168.0.100 ( my do not have the port)
Device File : D_DigitalSecurityCamera2.xml
Direct Stream : /videostream.cgi
Url : /snapshot.cgi
User : admin
Password : blank
important: if you do not put MAC do not works !!!
Did you manage to get the pan / tilt to work?? Or the motion sensor - I am thinking of buying a 9821 but would rather get the 8910e with power over Ethernet and have more functionality??
Cheers
J
Pan , tilt e motion sensor works perfectly !
I am using wifi mode in mine.
Are you sure you have a F19821 as snapshot.cgi doesn’t work with the F19821 when used from a browser?
did you try the impl_file: I_FoscamPTZ.xml
I have just tried FoscamPTZ implementation file but no difference. I have had a look at the implementation file and it doesn’t appear to implement the actions for getting the stream and still image so changing the I_ file probably has no effect until the camera is accessible. It would be interesting to see the image capture actions but I have no idea where I can find them.
Did you inserted the mac address?
Yes, I have entered the Mac address. I did find for my older F18918 Foscam that the Mac address was necessary so I have been doing that.
mac adress is neccesary for storing picture/video on micasaverde servers.
i changed the device file to D_DigitalSecurityCamera2.xml and this seems to work too. also changed picture quality to high and still working.
can’t get the motion-sensor to work and pan/tilt also not working.
anyone get this to work on FI9818w ? i used the I_Foscam98HD.xml , this gives me the 8 preset numbers in deviceview but no ptz nor preset work.
edit: got PTZ and preset to work see here : [url=http://forum.micasaverde.com/index.php/topic,11027.msg112616.html#msg112616]http://forum.micasaverde.com/index.php/topic,11027.msg112616.html#msg112616[/url]
@twostep make sure you have set the sub-stream to avi. see my former post.
Yes, I have run the camera avi command and get a result status of 0.
When I use the snapshot Url setting : /cgi-bin/CGIProxy.fcgi?cmd=snapPicture&usr=admin&pwd=xxx I get the piece of film icon where the still image should display. If I use the earlier models snapshot.cgi I get the ‘Invalid Url’ message displayed. I assume from this that url I am using for the 9821 is correct.
@Da_JoJo can you post the video settings you have on your 9821 or have you found that they all work with your setup?
I have Presets working and Pan/Title but still can not get the Motion Sensor to work.
its all in here http://forum.micasaverde.com/index.php/topic,11027.msg112616.html#msg112616
i will update post when something changes. i have a FI9818W btw
edit: updated post and added modified implementation file to add video :slight_smile:
needs admin account and you have to set parameter to “on” status. 98 series foscam have different commands which needs to change in motionsensor implementation file.
I have a Foscam 8910W, all set up working fine. When I am on my home wifi i can see a live video stream on my Vera UI5 foscam device (when i click on view on the device). When I try the same over the internet when i am out of the house i only get a snapshot or static picture. I have to close that child window, click on view again and i get the next snapshot, but no live video stream. Is that normal ?
yes. you need to fill in the external ip in camera settings to see video cq sequenced pictures
If you use foscam HD camera please update firmware to 18-4-2013 version [url=http://www.foscam.nl/index.php/support/downloads]http://www.foscam.nl/index.php/support/downloads[/url]
read the manual also before you ruin it. do not use iptool and it needs to be on cable.
