Foscam FI9805E Alternate
I am looking for a camera to install over my front door to interface with motion and/or doorbell. I want night vision, motion trigger and POE. From what I can tell, only the Foscams will provide a motion trigger to Vera. I am currently looking at the Foscam FI9805E. But at $200, I am wondering if there any other cameras I should look at and will accomplish the same thing.
Also, what is the motion detection trigger range on these? I only want to trigger motion within 10 feet of my front door. My street is 30 feet away so I don’t want a trigger every time someone drives down the street.
Thanks.
Another question is do you have an NVR (Network Video Recorder)? For the price, one of the best option is BlueIris, at $49 you get a license for up to 64 cameras and it will record the video and audio on motion or non-stop which ever you choose.
The cameras only have a sensitivity level of 0-10, I use BlueIris to send my motion alerts to Vera since I can Mask an area off like a street or a tree with limbs that move around to not set off the motion. This gives you alot more control and less false alarms plus you have recorded video in case something does happen you can give a copy to the police.
To do this I have BlueIris run this code on motion:
c:\BlueIris\wget.exe "http://VeraIPAddress:49451/data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=73" --delete-after
The last part is a Scene that sets the motion trigger for the front door camera which looks like this:
[code]-- Set Motion Sensor on Front Door Camera
function SetMotionSensor()
luup.variable_set(“urn:micasaverde-com:serviceId:SecuritySensor1”,“Tripped”,“1”,113)
luup.call_delay(“SetMotionSensor”,0)[/code]
And then I use PLEG to wait 2 minutes and reset the motion sensor to 0. This has been working very well for me.
I looked into Blue Iris but it appears to be computer software and I don’t keep or want a computer running. I don’t have an NVR and am not familiar with that.
You are correct, in order to run BlueIris you will need a computer on 24/7. If video is important to you than this is a must, if not than you can use the basic motion sensing on the camera.
You can read several threads on here about trying to have Vera monitor your house with snapshots and recorded video but the results are the same with Video and dedicated alarms systems, Vera does control very well but for Alarms and Video you are better off with dedicated systems that tie into Vera.
I see you are just starting, beware, this gets very addicting quick. I started out with Vera, Thermostat and a Yale Deadbolt w/keypad. A year later I now have every light in the house including closets and bathrooms, cameras, garage doors, alarm system, sprinkler system and about to do blinds. The great thing is since I did it my self I have still spent under $1500 for all of it.
Well, that is not going to work. I dont have a computer and I wont get one just for video. Can I just use a DVR? I do not need the DVR to be compatible with Vera as long as the Camera is. All I want to be able to do with Vera is have the Camera signal motion to Vera and be able to send a snapshot at request. If I need to retrieve video, I would just use the DVR for that and do not mind if it is separate.
I am aware of the addiction, thanks. My plan is to one room at a time, starting with the front entry. I will do everything myself, except for maybe interfacing the alarm panel. I am still looking into that.
Yes you can use a dedicated DVR, just check the forums to see which ones work with Vera, what your looking for is a DVR that has a SnapShot URL for Vera to consume.
As for the Alarm Panel I was also a little worried in the begging, but if I knew then how easy it was it would of been the first device I integrated since it only cost $99 and took me 30 minutes from start to finish and I was able to then use all the motion and door/window sensors in Vera. It was the best bang for the buck.
All you do is
  1. Buy the EVL-3 ([url=http://www.homesecuritystore.com/p-2164-evl-3-envisalink-internet-alert-module-for-dsc-honeywell-security.aspx?gclid=CK74nvfkrbsCFaTm7AodkxYANw]Home Security Store | The Best Home Security Systems for $99
  2. Call your alarm company and tell them to put you in test mode for a few hours
  3. Unplug the alarm in the attic
  4. Wire in 4 wires from the EVL-3 (Video Instructions on link I supplied)
  5. Plug a network cable into the EVL-3
  6. Plug the alarm back in
  7. Install the DSC Alarm Pluging
  8. Enter the IP Address of the EVL-3 into the DSC Plugin and enjoy
Thanks Chris, I have already been looking at some threads regarding Vera comparable DVR’s. Knowing the feature is called SnapShot URL will help me a lot with this.
On the Alarm panel, I have actually been discussing it with Ruetech on the side. In searching the forums, I noticed he is the only person who advocates DMP panels and that is what I already have installed at my house. I am looking at some different option to integrate it with Vera. I do not believe the EVL is compatible with the DMP panel but will look further into it. Ruetech accomplished the integration with an Adruino product. I’m too green to jump is head first with the programming rquired, so I was thinking of wiring in a MimoLite module on a few interested zones as a start. What I really like about my simplified approach is that the MimoLite product is a Z-wave native so integrating it into the Vera will be easy.
When I get to a point where I am satisfied with basic functions and I’ve built up some sweat equity in the Vera programming, then I may try to recreate what he pulled off with full integration. Well, that and incorporating 22 MimoLite units might be a bit overkill.
Thanks Chris H!
Here I’m looking for motion detection in Vera and stuble into this. Seems so easy.
I’m about to get me an alarm. Waited for a year for a european version of DSC with z-wave.
Only things that puzzle me now is tahe the EVL-video said “if your stuck with an old alarm before smartphone revolution, tgis device can step it up to it”.
Then seems like the should be a more newer updated alarms with webinterface and smartphone integration (since I don’t want a ugly number pad panel to turn on/off the alarm).
I think it’s a shame there is a nice neat interface for e.g. a 7 inch wall mounted android and with small bilding blocks that can add home control from favourite controls/scenes and from map (Vera handling - not veras interface), current power consumption, temperature, camera, wheater, alarm etc.
All now is nice home made builds, but they’re not public and standardized (I probalbly don’t find time and get all the skills to accomplish one myself).
One applaud from me…
