I recently installed and setup a Foscam FI8918W camera using the DIY guide here…
http://forum.micasaverde.com/index.php?topic=3720.0
Everything seems to be working, except the left/right controls are reversed. Is there a way to fix this?
You will need to upload the revised I_xml
See here:
http://forum.micasaverde.com/index.php?topic=3591.msg48774#msg48774
JOD.
Got it. I downloaded the file, and once I upload it is there anything else I need to do?
Upload the I_xml and then replace the camera’s imp_file reference with I_Foscam8918.xml
JOD.
JOD,
How do you replace the file once it’s uploaded? I have two Foscam F1918W cameras.
If you’ve made changes to a file and the file has the same name, when you upload it, it will replace the other file.
But I have a feeling that’s not what you were asking…
The I_xml in the impl_file location is what dictates what file the camera device uses.
JOD.
Thanks, JOD, I got them both working with the correct buttons.
