OK, I give up and I’m starting a new thread, sorry guy’s…
I’ve gone through every Foscam article out there and can I hell get the PTZ function working on a FI8910W device. I’ve tried ever permutation of D_DigitalSecurityCamera2.xml/json with I_FoscamPTZ.xml and with the Foscam Plugin and without it. All the articles I’m reading are from 2012 and god knows things must have moved on.
If there is someone using the FI8910W on 11.37.2.54 with Vera Lite UI5 1.5.622 then please please please… upload screenshots of your settings and D_DigitalSecurityCamera2.xml/json with I_FoscamPTZ.xml as I’m all out… I see the image, i see the pre-set’s and pan options and i can archive images fine, but the pan and pre-set buttons do nothing (it’s not disabled on the camera).
I don’t have this camera (or any), but I noticed the “commands” variable. This doesn’t show up in your screen shot, so I just thought I would throw this out there.
I just spent several days pulling my hair out with 2 of the same cameras. They kept dropping offline, wouldn’t respond to commands, etc. After starting over they seem to be rock solid for the last 3 days. Hopefully they stay that way. Here are some details:
Device firmware: 11.37.2.54
WebUI: 11.37.2.54
Wireless LAN set to WPA2 Personal (AES)
Currently I have DHCP off with a static address but if you turn it on you will likely get Vera to download the VistaCam plugin
VistaCam SD, PT & HD for UI5 app version 1.44
In the device on Vera under the settings menu I have:
URL field: snapshot.cgi?user=XXXXX&pwd=XXXXX
Username: XXXXX
Password: XXXXX
IPAddress: 192.168.x.x
Under the Advanced tab I have:
device_type: urn:schemas-upnp-org:device:DigitalSecurityCamera:2
Device file: D_DigitalSecurityCamera2.xml
impl_file: I_VistaCamPT.xml
Commands field: camera_up,camera_down,camera_left,camera_right,camera_full_screen,camera_preset,camera_archive_snapshot
DirectStreamingURL: /videostream.cgi?user=XXXXXX&pwd=XXXXXX
URL: snapshot.cgi?user=XXXXX&pwd=XXXXXX
While I have an 8910 camera, it seems to be using another plugin. I have an easyn camera that is using the 1978 plugin and have no problems. The information that you provided in your screen print very closely remembles mine. I am on version 3.0 of plugin 1978. If you can tell me what files you need, and where to find them, I will certainly try to help. Hopefully beerguy has your answer.
Thanks pwlivewire for opening up this thread. I have been struggling myself with this F18910W camera. At least from everyone’s input so far I have gotten the my picture/image back from the camera as I was doing some weird stuff (deleting things - so frustrated). ‘beerguy’ mention to use this plugin “VistaCam”, but when I did that I would get some message saying “Not ready for control” when I try to scan with the camera; hence went back to the I_FoscamPTZ.xml.
pwlivewire - did you get your camera resolved? I don’t know if you are having the same problem as I am.
Problem1: I cannot get “live” scanning. I would have hit the left or right arrows a few times and then, close window, and relaod. Only then I will see the NEW image.
Problem2: My left and right arrows are backwords. When I hit right the image goes left (remember not instantaneously though)
I pretty much have the same parameters for Settings/Advanced as everyone else.
F18910W
Firmware: 11.37.2.55
Web UI: 2.4.10.9 (does this sound right?) If not, I went to Foscam and they sent me this along with the firmware update.
Thank “TheSamurai”!!! That really helped. I changed the tilt/pan to “1” and that took care of ALL the directions. From everyone’s screenshot it appears that 0 was used by everyone. Weird.
For some strange reason I left my foscam connected to the network (for over a week) and did not do anything until now … so frustrated and it NOW works as I expect. I can get instantaneous feedback from the camera with no reload. I swear I did not do anything. Maybe VERA needed to slowly marinate or something. Let me know if you need any screenshot image of my settings since it seem to working now.
Wow, I really don’t want to touch it now that it works, but I have to move it to where it needs to be. Hopefully, I can get the same working state as it is now. Thanks everyone! Plus, I need to order another camera since this one is now working.
OK, I solved it, took a little figuring out but after awhile i realised what I missed.
After punching open the I_FoscamPTZ.xml I realised the commands it was sending was nothing more than;
/decoder_control.cgi?command=30 Set Preset 1
/decoder_control.cgi?command=31 Goto Preset 1
/decoder_control.cgi?command=32 Set Preset 2
/decoder_control.cgi?command=33 Goto Preset 2
/decoder_control.cgi?command=34 Set Preset 3
/decoder_control.cgi?command=35 Goto Preset 3
/decoder_control.cgi?command=36 Set Preset 4
/decoder_control.cgi?command=37 Goto Preset 4
etc…
/decoder_control.cgi?command=6&onestep=5 Step left 5.
/decoder_control.cgi?command=4&onestep=5 Step Right 5.
/decoder_control.cgi?command=2&onestep=5 Step down 5.
/decoder_control.cgi?command=0&onestep=5 Step Up 5.
You get the idea, but then I realised that it was also passing variables in for the username and password with lug_username, lug_password. I then tracked that variable down to the Settings tab Username & Password, now i was told to leave these blank as I was piping them into the URL for the snapshot.cgi but it turn out the xml file pull’s these 2 fields instead and ignores the URL ?user= and &pwd= fields.
long story short, goto the camera settings page and enter:
URL field = /snapshot.cgi?user=&pwd=
Username field =
Password field =
Don’t worry about duplicating them, it’s required, Pan Tilt and preset’s all working. ;D
@pwlivewire, Do these offer any kind of recording? I don’t care if it’s through the vera. For instance, if someone comes to my front door, I would like to record a period of time and save it somewhere. I would then like it if the Vera could also snap a picture and send it to me. I would love to get one of these today (actually the POE version) and install it saturday on my front porch. Foscam are suggesting I go with either the FI9805E (outdoor and POE, but no PTZ) or the FI9826W (Indoor, PTZ but no POE without a “kit”).
I’m sure that the 8910E will do just fine and is significantly cheaper than those options, so I’m heading in that direction. I’m just concerned about the recording as I do want a record of who comes to the door.
They don’t do video no, BUT the camera itself will email a chain of 5 images with a second burst between each one to an email address on motion detection. You can also using a PIR through Vera capture an image and store it in Vera archive for a set number of days for review.
Hope that helps
[quote=“pwlivewire, post:15, topic:179305”]OK, I solved it, took a little figuring out but after awhile i realised what I missed.
etc…
Username field =
Password field =
Don’t worry about duplicating them, it’s required, Pan Tilt and preset’s all working. ;D[/quote]
Thank you so much!!! this did it for me you have to duplicate name and password in the URL and the username and password box!
