Foscam FI8910W improperly configured (No gateway)
I installed my Foscam FI8910W and I am getting an error that it can’t find the gateway:
Foscam Camera : Missing Gateway IP address
The problem is that no where in the camera’s configuration pages is there a place to enter the gateway address.
I manually added the camera and have the following plugins to support it:
VistaCam PT&HD IP Cameras 1.1
Foscam IP Camera 2.6
But something clearly is not working right
Any ideas?
Easy try, just power down the camera, vera and your DSL. Wait a few minutes then power it all back up, vera should find the camera and update the settings. Worth a try till some else can chime in.
Hope it helps Bill
Thanks Bill. Did that a couple of times…no dice :frowning:
Ok, so I think I figured it out.
Per the documentation here VistaCam PT&HD IP Cameras
I changed the state to 1 to enable motion detection.
Guess what? That’s wrong (at least for me) it was not at 0 when I started, it was at -1. I changed it to 0 and then all is well. No error. AND my motion detection is working.
Hmm.
I just checked mine it was on “2”. I changed it to “1” and got the massage “missing ip…”. Changed it back to “2”. it seems to be working eksept from the pan and tilt, it is going in the wrong directions.
It is an FI8918.
There must be some documentation.
Maybe thats why I cant get pictures on VeraAlert ??
Regards
CE
get rid of the foscam plugin and install the vistacam motionsensor plugin. the gateway is your vera ip btw. check the plugin section on this forum for the rest of the info.
Got the Foscam FI8910W as well. Same here: state default -1, with 0 motion sensor is enabled. Wouldn’t have figured that out in ages, thanks @LH!
