Just purchased this camera and set it up on my network. Pretty descent improvement over the Foscam F18918W models I?m currently using, however, I cannot get the camera to work within Vera. Latest version of vera U15/foscam plugin/ etc.
from what I can see the main difference is the 31 is a 1.3megapixel 960p while the 21w is a 720p.
Having said that I have no idea if thats a big difference or not as I have little experience in cameras/images.
Just reading up I can advise the following for future readers. I purchased originally 2 F18910W then I purchased a F19831W, Flyveleder has mentioned the F19821W.
My original F18910Ws just worked and the setup was plug’n’play in vera with no issues. Problem is their quality is very poor. The F19831W quality is truly superb but setting it up has been a pain and I’m still not were I should be with it.
I know that the F19821W will be less quality then the 31W but to what degree… if it is a plug’n’play then I would take that.
Flyveleder… was it just a plug and play and all worked. If so I might just have to get one to check it
Flyveleder… was it just a plug and play and all worked. If so I might just have to get one to check it :)[/quote]
I have 4 FI9821w v2’s a FI8910 and some Panasonic’s. I have not but would like to get some Fi9831w’s soon so I can’t compare the quality on those.
Big jump from the 910’s to the 21w’s. None of them have been plug and play setup for me. The 21w’s I have to play with the same settings that you are now to get them to work. Lucky for me the cameras were out for sometime and people already had the work around. If the same doesn’t work for the 31w’s I’m assuming it will be a short time and someone will have it up and running. Really in the USA the 31w’s have only be on the website for 2 weeks or so. It’s just to new at this moment.
Then go to the properties of your camera device and replace the URL variable with: CGIProxy.fcgi?cmd=snapPicture2&usr=admin&pwd=pwdhere& (replace pwdhere with your password)
That should do it!
It appears that Pan and Tilt does not work yet. Anybody?
That should do it!
It appears that Pan and Tilt does not work yet. Anybody?[/quote][/glow]
Tried your 4 steps, then replaced the URL variable and i still cant see a image on the dash board. all the comes up is a blue looking camera. correct me if I’m wrong and have to view it autmation but its not even showing up in there either.
Maybe someone on here can help me. I have a problem with only half a picture being displayed on the Vera device for my FI9821W. I have posted this as a seperate thread [url=http://forum.micasaverde.com/index.php/topic,25235.msg177706.html#msg177706]http://forum.micasaverde.com/index.php/topic,25235.msg177706.html#msg177706[/url]
I now had the idea of looking at people who got the FI9831W to work which is even higher resolution. I am starting to think that maybe my cameras are using the wrong plugin.
So 2 questions. Do you get a normal picture on your Vera UI device or is it cut of ? Like i have posted in my thread
Is there a plugin number when you go into your advanced settings ? Mine is blank. I also never had the chance to select ‘Other IP camera’ for type when i added mine manually.
Actually i have one more question… which impl_file are you using ? I am using I_Foscam98HD.xml
[quote=“mikee123, post:10, topic:178287”]Maybe someone on here can help me. I have a problem with only half a picture being displayed on the Vera device for my FI9821W. I have posted this as a seperate thread [url=http://forum.micasaverde.com/index.php/topic,25235.msg177706.html#msg177706]http://forum.micasaverde.com/index.php/topic,25235.msg177706.html#msg177706[/url]
Actually i have one more question… which impl_file are you using ? I am using I_Foscam98HD.xml[/quote]
I have several 9821w v2’s and I have a full picture.
Yes I’m using “I_Foscam98HD.xml” also
Device file “D_DigitalSecurityCamera2.xml”
Device type “urn:schemas-upnp-org:device:DigitalSecurityCamera:2”
If you are at a loss, I suggest to enable remote support and put a ticket in with Vera support. After a month of trying to get PTZ to work on my 9821 with no luck, the Vera support guru had it down within 24 hours of me submitting the ticket.
As for quality, I’m a mite disappointed in the 9821. It’s aimed towards the window (with about 1% of the picture being window) and the picture is very washed out due to the light from the window. I left the 8910 in place about a foot away from it aimed in the same direction (about 9% of the picture is window) and the image is far crisper and barely washed out. At night with the blinds closed and the light on, the 9821 produces a lot better image although the brightness level seems to waver a bit.
These are exactly the settings I am using now, and had before it stopped working properly. Very strange. I tried creating another device, same result. I will try deleting the plugin tonight and starting again…
These are exactly the settings I am using now, and had before it stopped working properly. Very strange. I tried creating another device, same result. I will try deleting the plugin tonight and starting again…[/quote]
Hmmm been awhile since I installed them, right when the V2 cam out I got them. POS cameras tho. not one of the 21w’s ir’s work right anymore. All have some or all out, and when the IR’s flicker on and off they throw off the motion sensor. Basically useless at night right now. Day is OK looking to upgrade when I have some $ to a fixed 3MP camera for 160.00. I paid 100.00 for these foscams at the time from GROUPON and have 4 of them. I installed them in 15 min without any issues following the instructions on this site somewhere.
My 8910W is still working good just not as good picture quality but IR’s are all working.
EDIT:
Also I should note I wanted Pan and Tilt in the beginning but I have found I no longer use it and if my wife, myself or my kid accently hits the pan and tilt. It throws off my shaded out motion area’s and nearly impossible to move back to the same place again without just redoing the blocked out area. So I’m thinking a Outdoor fixed camera in a metal housing with POE is going to fit me alot better. Probley a Hikvision DS-2CD2032.
I currently have extension cords in my attic taking power to the corners of my house to power these foscams up. And Wireless was a joke, never could get it to stay up and running for more then a week without having to reboot it and quality was worse, so I have Cat6 (which can now power my POE and I can remove the mickey extension cords). Mic works ok, but speaker to return talk doesn’t work at all. I use Blue Iris (which is great) to run all the motion, remote login and everything else foscam’s can sort of do with their internal software, but never really worked right.
I was happy when I got them, told everyone about them and the price for $100.00 Pan and Tilt, mics, speaker and more. But now all of them know buy something different.
I also have a 8910, but find the motion sensor utterly useless. I have stopped using it, and have not even attempted using it with the HD cams, and I think I remember its not working with the HD cams
Same here. Blue Iris running on my WHS2011 server now handles all camera’s as I got tired of the troubles getting my cameras setup in Vera.
Using Blue Iris give me a much larger variety of IP camera’s to choose from then I have with Vera. I have 6 Foscam units and although I am very happy with the 8910’s, I’m pretty disappointed in the 9821 v2 and when a camera breaks I’ll definately will be looking around for a better quality brand.
The reason I needed my 9821 working on Vera is that I use AuthomationHD and Imperihome to check the camera in teh l ivinroom to keep an eye on my dogs while I am at work.
Question. What plugins have you got ? I have Foscam SD 8910W and the HD 9821W. I have the following on my Vera and wonder if that might cause problems:
VistaCam PT&HD IP Cameras 1.1
VistaCam Classic Motion Sensor Plugin 1.22
Foscam IP Camera 2.6
only the Foscam plugin has a device listed, my 8910W. The 9821W is not listed with any of the plugins
