Just got my new Foscam F18918W working using: http://forum.micasaverde.com/index.php?topic=3720.0
Is there any progress on getting the motion sensor to work?
I notice that they sell a vera with Foscam support already enabled,http://www.ipcam-central.com/Vera_2_p/vera%202.htm
Also similar instructions here to get it to work: Vera2 Foscam confguration settings using a file I_FoscamPTZ1.xml
Anyone know if it uses the motion sensors?
I can’t get any movement control or live video on my Foscam through my new vera2 can anyone help?
I have installed the Panasonic extra plugin and the updated .xml file I found on the thread http://forum.micasaverde.com/index.php?topic=3720.0 but the system appears to force the Generic IP Cam despite trying to force a manual install using the Panasonic IP cam plugin. I can manually move the Camera and take a snapshot using the attached foscam.sh if I place this in the vera busybox, so I know I cam talk, control and take snapshots and video from the point of the vera2 busybox device, but for some unknown reason the Camera plugins will not work!!!
My Camera reports the following information by way of the attached script
var id=‘000DC5D29D37’;
var sys_ver=‘11.22.2.30’;
var app_ver=‘2.4.18.15’;
var alias=‘’;
var now=1322571456;
var tz=0;
var alarm_status=0;
var ddns_status=0;
var ddns_host=‘’;
var oray_type=0;
var upnp_status=4;
var p2p_status=0;
var p2p_local_port=23910;
Vera2 Version You are running the latest version: 1.1.1245
