I have a simple question - I want to use my 9821w v2 Foscam for motion detection in VeraLite - is there anybody here who can help me with that?
I’ve managed to add camera to VeraLite UI5, but motion detection is simply not working.
No one, eh? Well… seems like that Blue Iris unofficial is only viable way - too bad camera can’t be setup to work without that.
I believe there is a way, I have the same problem will keep you posted
There is a way - I saw that numerous people on the forum say they’ve solved the problem. The easiest way I see now if you are on UI5 is to pay another $50 for Blue Iris and then use this plugin: GitHub - undert03/vera-blueiris: Cam / Sensor plugin for Blue Iris IP Cam DVR
I’ve managed to add camera with pan&tilt… once you know what you are doing it’s actually quite simple, you just use that Vistacam PT,SD&HD plugin. But motion sensor is not working… and I’ve actually had 3 sessions with their support - even them can’t make it to work.
So please do update me if you manage to get motion sensor working - I’ll post here also if I find solution
I also can’t get motion detection to work. Foscam 9831w.
