I have a Foscam 8910W, and it all works fine with my Veralite and UI5, pan and tilt works well to. I thought the camera had a motion sensor too, but none shows in Vera. I have gone through the forum, but it seems it cannot be activated in Vera, at least not with the older models, so maybe it doesnt work with this model. In settings i get the following:
Archive a photo whenever the following sensors are tripped or doors are opened:
_4 in 1 sensor (motion) only when it’s armed all the time
so it does see my Aeon multi sensor, but now the one in the camera. Did anybody get the internalk motion sensor to work in Vera ?
Look in the Advanced tab of the camera for a variable called ‘ConfiguredMD’ or ‘State’ (depending on the version of the Foscam Plugin you are running). Change this Value to ‘0’ and then Save.
Fantastic. That worked, i now have the motion sensor of the camera as a seperate device
Thanks very much !
One more question. I now want to get the motion sensor to trigger a light for 3 minutes, and take a snapshot. I have ticked take snapshot in the settings, so that will work i guess, can probably access it by clicking on the archive button of the device. To trigger the lights for 3 minutes, its probably easiest to set the timeout for the motion sensor to 3 mites. I have seen a setting in the motion sensor, OnTime which is set to 1200, i guess if i set that to 180, that would do the job ?
