Fortrezz wwa-02 ?
Anyone using this with Fortrezz WWA-02’s
Am running 1.4.1 of app with vera2 ui4 , fortrezz temps showing as “?” in app.
Tried beta 2.0.1.2 as well… I like the look… easier to see.
WMA-02 still showing ? though
Would you be willing to provide me data so I can see what the data looks like to add support?
  • Garrett
Tell me what you need or how to get it and I’ll hook you up.
Thanks!
Les
Can you provide me your lu_sdata so I can look into it? You can retrieve the lu_sdata by going to the following link:
http://ip:3480/data_request?id=lu_sdata
Where ip is the vera ip address. Before you send it off, please go through the data and carefully remove any passwords or sensitive data you might have. You can take the data and put it into a json formatter found here: http://jsonformatter.curiousconcept.com/ to have the data be easily readable. You can than send the data to authomation at garrettpower dot com.
Hopefully I can get enough information to support the device.
  • Garrett
Any way I can pull that remotely via fwd1/fwd2 ? That vera is 3 hours away so have no local access to it. (normally I could vpn in but something has been flaky with the vpn on that router for last few weeks)
I can provide that data in about for hours, I do have some wwa-02 sensors. But I got to get some real work done before I can go home and post that… ;D
are you talking about this wwa-02: Ezlo – Property Empowered
or is the wma-02 something different?
EDIT: If you mean the wwa-02, see an excerpt of user_data.json in the attached text file.
my bad… wwa-02 (just fixed subject line too… man do I feel dumb mistyping that one!)
yeah thats it…
Thats what I get for not wearing my glasses and using the computer…
Doesn’t matter, I was already adjusting my forum signature until I realized it probably was your typo and not mine ;D
garret, let me know if I can help with any further data if the above posted text file is not enough info.
since i was planning to get one i did some research on it . the difference between the 2 wwa-002 is that one has AA batteries and the other one has a lithium cell. thats about it.
No beeper on the wwa-02, just led. This was the reason I got this model. They are sitting in places at a rental property that visitors can’t get to, so I figured 1. Longer life if no beeping when a problem. 2. Doesn’t drive someone up the wall to have something beeping that they can’t get to anyway. 3. I still know the temp and get alerted remotely. 4. Supposedly has better zwave performance.
The data I provided is from a wwa-02 with led, no beeper. Overview: Ezlo – Property Empowered
[quote=“chixxi, post:7, topic:170784”]I can provide that data in about for hours, I do have some wwa-02 sensors. But I got to get some real work done before I can go home and post that… ;D
EDIT: If you mean the wwa-02, see an excerpt of user_data.json in the attached text file.[/quote]
Chixxi,
Thanks for the data, however I need the lu_sdata version.
Les F,
You can get the data via the fwd1 / fwd2 by doing the following:
https://fwd1.mios.com/[b]username[/b]/[b]password[/b]/[b]unitid[/b]/data_request?id=lu_sdata&output_format=json
or
https://fwd2.mios.com/[b]username[/b]/[b]password[/b]/[b]unitid[/b]/data_request?id=lu_sdata&output_format=json
  • Garrett
@garrettwp
data on its way in email to you… thanks!
Les F was quicker 8)
well then, I don’t think you need a second set of data, otherwise let me know.
Wanted to get support added for the fortrezz. Can someone provide me what the device looks like via Vera’s UI? I would assume it is some sort of security sensor showing temp?
  • Garrett
There you go garrett, screenshots are attached. Let me know what else you need to see.
BUT, I still think the sensor should have an option to arm/disarm the leak-sensor. When you add a device like this in a scene’s advanced menu it also provides an option to arm/disarm the sensor (see screenshot 3). If you look at the device in the smartphone web interface (MiOS Apps) it does have buttons to arm/disarm. Should we maybe even file a bug for this one?
Thanks for the info. I will incorporate this into the next alpha release of AutHomation 2.1. I will also add the arm/disarm buttons as it shows them in the device file.
  • Garrett
p.s. Not sure if you looked in the AutHomation 2.1 alpha thread, but I added variable container support. Let me know what needs to be changes, fixed, or added.
