[quote=“watou, post:1, topic:176420”]Hi,
Yesterday morning my WWA-02 leak detector reported a leak in my basement and it continues to report there is a leak. After considerable inconvenience, it was determined that there is (thankfully) no leak or any atypical moisture in my basement at all. It repeatedly caused notifications to be sent until my quota was hit for the day.
I have not seen this device issue false positives before, so now I’m interested in learning if others have seen this as well, and if there is a way for resetting the device remotely via Z-Wave so it can regain its sanity. Any thoughts or similar experiences?
Thanks!
watou[/quote]
I have this problem often, with both the older (single 1/2AA battery) and newer (two AA batteries) models. The problem seems MOST likely when, in my case, the sensor is in an environment of 40degF or below, but it has occurred in warmer temps.
Typically, when these events occur, I receive notifications every 30min until they clear. I assume this 30min recurrence is a function of the Vera2 I’m using and not the Fortrezz devices.
I do not believe the above problem is, in my case, a function of weak RF signal conditions and consequent message loss or corruption.
I’ve noted other oddities when the devices ARE in poor RF signal conditions, i.e., (1) the Vera will report low battery (I think this is an indication that the Wakeup interval messages are being lost; watch the LuaUPnP.log file for the presence or omission of “batterylevel” logs which evidently occur at every Wakeup interval) and/or (2) off-the-scale temperature readings are being reported. I might add that (3) bizarre or repeated alarms, as are the subject of this thread, might also be precipitated by poor RF signal conditions.
Cheers!
(what follows is additional information since I posted the above)
It’s cold here today (IL) and my sensor in the attic is registering 39deg. Coincidentally, it’s starting to report erroneous leak alarms, as it has done before (as I noted above). This has to be more than just “coincidence”; maybe the folks at Fortrezz could tell us why this happens, but I won’t hold my breath waiting to them to deliver.
