I’m setting up a Fortrezz water valve and can get it connected to Vera OK and can open and close it from the computer, but then when I power-cycle the valve it doesn’t seem to reconnect to Vera. The mode light on the valve blinks (single blink) but I can no longer send commands to it – “Transmit failed with code: 1”. Re-pairing it with Vera fixes the issue, but it should reconnect automatically in case of a power outage.
Has anyone else had this problem?
My thermostat and door lock reconnect fine.
Thanks a lot,
Alex
