Ui7 on Vera Edge with 7 fortrezz water sensors… 2 of them just keep reporting “Device NOT responding again” "
Tried new batteries, and exclude and include again…
Also thought that these two units were to far from the Edge, so I got a 4 repeaters and installed 3 new Aeon light switches… in an attempt to get more neighbors…YES ran the repair
Running firmware 1.7.961 latest as of today FEB 28 2015
Anyone else been having issues with these sensors?
Same issue here, latest ui7 veralite. 2 out of 6 of these sensors will report not responding /responding again usually within minutes. Happens pretty much daily. Lots of devices around and not far from the veralite (15 feet through one drywall wall).
i know the post is old, and there is a fix… it comes down to adjusting the polling time for each of the sensors.
Set the wake up interval to 43200
this tells Vera to only check on the sensor based on when the sensor is actually going to wake up… not when its asleep / battery saving mode, which obviously it fails to get the proper signal back leading to the failed device…
i found this to also work with other battery operated devices…
keep me posted on how you make out
