Fortrezz Water & Freeze Alarm (WWA-02)
Hi -
Does HomeWave support this device? I can see the temperature but I don’t see the water sensor alarm status. Anything that I can do on this end to either provide more info?
Thanks.
[quote=“beerguy, post:1, topic:175064”]Hi -
Does HomeWave support this device? I can see the temperature but I don’t see the water sensor alarm status. Anything that I can do on this end to either provide more info?[/quote]
I have 2 of these devices and they will show both Temp and Sensor. The Sensor needs to be configured as a separate device (Sensor Indicator), so each WWA-02 will show up as two devices.
See attached screen shot.
OK. Thanks. I think I have a bad sensor because I can’t even get the led to blink when the sensor is in water so I have a feeling I have bigger problems than seeing it in HomeWave :frowning:
Turns out I did have a bad WWA-02 but I’ve replaced it and still can’t seem to see the water alarm in HomeWave. When I add a device with the + in HomeWave, then choose Sensor Indicator I don’t have a choice of my WWA-02s. If I choose Sensor Measurement I get all of the WWA-02s temperature readings.
Is there something that I need to do in the Advanced Config for these devices in Vera? Is there something else in HomeWave that I should be doing?
Thanks.
Edit: I forgot to mention that I’m on beta 1.49.6
Figured out what was going on. You have to trigger an alarm with each sensor before it will show up in HomeWave as both an Sensor Indicator and a Sensor Measurement device.
Very interesting. I was trying to recreate your problem and can confirm that the Sensor Indicator does not appear as a select-able device if it is not first tripped (I removed one of mine and attempted to re-add). I don’t know if that is ‘new’ functionality. I don’t recall having that problem when I first went through the process of adding mine in Homewave.
Intveltr…does that sound like it is Working As Designed?
This is probably because when the device is first added, not all the proper variables are populated. In this case the tripped variable was not populated until it was actually tripped. This is pretty normal.
  • Garrett
Correct: HomeWave determines the device’s capabilities by inspecting the reported variables.
