Fortrezz Siren new Template
Can anyone write a new D_Siren?.xml and D_Siren?.json for the Fortrezz SSA2 Siren.
Using Siren1 files does not enable all features
From Fortrezz themselves:
"To enable the Strobe and the Siren to work independently, you have to use it with a z-wave controller that has it supported in this manner. Not all Z-wave controllers can do this.
Essentially, the device should show up as a DIMMER LIGHT SWITCH. Based on the below dim value, it will act differently.
1-33% dim value = strobe only
34%-66% dim value = siren only
67% - 100% dim value = both
I know this can be achieved by setting it to a dimmer lightswitch but if it is a dimmer light switch then it is not set to on when triggered by say a door sensor.
Why do I want this? So I can flash the strobe for 20 seconds when door is opened and in Away/Vacation mode then switch to Strobe+Siren
Help anyone?
Did you find a solution for this? I am trying to do the same thing. If you did, please share
