Forgotten Device Accidentally
How can I un-forget a device that I hit the forget button on? Is it possible without redoing my setup?
Yes and no. If you use the Vera email link to go in and decide which devices to show Alexa, you select them all, (possibly painful process if you have a bunch of devices) and then use Alexa to search again. She members your groups and will pick up the forgotten devices.
The downside, Alexa will pick up everything in your house again, which causes duplication sometimes. WeMo is good example. Works with Alexa, works in Vera for most.
Thanks for that, I’ll check it out.
Sent from my VS995 using Tapatalk
