Floorplan problem in firmware 862
I was playing with the floorplan(s)
I upload my floorplan (*.PNG, max size 35kb)
It will show my floorplan as a thumbnail but when i click “show floorplan” Vera will not load (show) it.
People having the same problem?
Any solutions?
Have you ever had it working before in any of the previous firmware builds?
Only in the 616 firmware.
All firmware’s after it did not work anymore. i also delted the files directly from the Vera (filemanager) and uploaded again. but this would not help.
I’m curious, Maartenvt:
When you uploaded the floorplan graphic, (a) which file format did you use (JPG, PNG, etc.)? (b) did you rename the section (i.e. from the default to “Interior”)? (c) did you later assign rooms to that section/floorplan?
It is a PNG file (see first post)
I first give it a name and second i uploaded the picture.
And yes i assign rooms (incl devices) to the sections.
We’re working on a completely new user interface that replaces the concept of ‘floorplans’, which were never fully implemented anyway. So the floorplan feature is considered deprecated.
