Does anyone make a flat wall mounted switch that doesn’t require in-wall installation or AC power? I’m basically just looking to put a switch somewhere there currently isn’t one.
Thanks,
Ward
Thanks,
Ward
I use the ZWave.Me Wall Controller for this. It works as a scene controller both for direct association to Z-Wave switches and via Vera scenes.
The latest version ZME-WALLC-S uses Z-Wave plus so requires UI7 or UI5 beta 1.5.672. The older ZME-WALLC also works with standard UI5 1.5.622.
See [url=http://www.z-wave.me/index.php?id=30]http://www.z-wave.me/index.php?id=30[/url]
Thanks. Where did you order it from? I’m in the States.
I would try Vesternet. ZWave.Me do have US versions of their products so they should be available somewhere.
I am using a few of these http://www.megamanuk.com/lightwaverf/products/remote-control/jsjslw221wh/ with the RfxTrx and lolodomo’s plugin.
