EvenTj
October 25, 2013, 7:05pm
1
My new Philips TV can accept JSONrequests through the Jointspace API?s, but I cant figure out the code to send a JSONrequest, can someone help me figure the error with this code? Trying to set the TV to Standby.
[url=http://jointspace.sourceforge.net/projectdata/documentation/jasonApi/1/doc/API-Method-input-key-POST.html]http://jointspace.sourceforge.net/projectdata/documentation/jasonApi/1/doc/API-Method-input-key-POST.html[/url]
function JSONTest()
requestNumber = JSONRequest.post(
“http://10.0.1.19:1925/1/input/key ”,
key: “Standby”,
function (requestNumber, value, exception) {
if (value) {
processResponse(value);
} else {
processError(exception);
Anyone know how to send a JSONrequest.post( ??
That’s a JavaScript library … Where do you plan to call it from ?
See: JSONRequest
EvenTj
October 26, 2013, 12:41pm
3
[quote=“RichardTSchaefer, post:2, topic:177520”]That’s a JavaScript library … Where do you plan to call it from ?
See: http://www.json.org/JSONRequest.html[/quote]
I want to make a scene which can turn on and off my TV using JSONrequest. How can I do this in the LUUP field? I thought I could run this code in the luup field, but offcourse no chance…
This is all based on http requests with JSON formatted objects … all doable in LUA … but you will need to do some coding.
skinnez
November 12, 2013, 6:53am
5
Did this work? Any ideas on how you could get pressing play or pause on the philips remote to run a scene??
Cheers
J
system
January 31, 2014, 10:07pm
6
Any information on how to integrale this Code in LUUP. This would be great.
