Hi I’m trying to use PLEG, seems impressive and very usefull. I want to use a virtual switch to arm or disarm PLEG, See below. However this doesnt seem to work. When i use the virtual switch nothing happens in PLEG??
Name Description Last Trigger State
AutOn Automation switch is turned on 2014-01-19 13:54:01.452 true
AutOff Automation switch is turned off 2014-01-19 13:53:57.799 false
Schedules
Name Type Time Days Random On Delay Off After Type Off Time Off Days Random Off Delay State Last Schedule
AutOnSchedule Weekly 12:00:00 1,2,3,4,5 None Weekly 13:00:00 1,2,3,4,5 None false 0
Conditions
Name Expression Last True State
cAutOn AutOn == 1 2014-01-19 13:54:01.453 true
cAutOff AutOff == 0 2014-01-19 13:54:01.457 true
Actions
Actions for Condition: cAutOn
Immediate
Device Action Arguments
Program Logic Event Generator SetArmed newArmedValue=1
Actions for Condition: cAutOff
Immediate
Program Logic Event Generator SetArmed newArmedValue=0
You can arm it manually from the Device Control on the Dashboard.
You can also arm/bypass it programmatically with the reserved condition names ARM and BYPASS
[quote=“RichardTSchaefer, post:4, topic:178956”]You can arm it manually from the Device Control on the Dashboard.
You can also arm/bypass it programmatically with the reserved condition names ARM and BYPASS[/quote]
I thought that BYPASS meant that actions are not fired; How can the action to change PLEG from BYPASS to ARM fire, if the PLEG is on BYPASS ?
[quote=“flyveleder, post:5, topic:178956”][quote=“RichardTSchaefer, post:4, topic:178956”]You can arm it manually from the Device Control on the Dashboard.
/Martin[/quote]
The special conditions for Arm and Bypass don’t need actions so they are not inhibited by the PLEG being in Bypass.
In the PLEG Basics pdf, it describes this special device action:
SetArmed - Set PLEG Arm/Bypass as specified by newArmedValue. 1 = Arm, 0=Bypass.
I have tried this and I can set the PLEG to BYPASS using this action, but once bypassed, it will not ARM by using the action “newArmedValue = 0.” Is that the correct behavior? However, I should be able to ARM or BYPASS a different PLEG by using this action, yes?
However, within the PLEG, I can still both ARM or BYPASS using the ARM & BYPASS conditions, correct? I am trying to set up some vacation parameters and still struggling with the best way to do it.
That should be removed from the documentation.[/quote]
I’ll remove it from the next version.
Yes. The ARM and BYPASS Conditions don’t require Actions so ARM will work even if the PLEG is Bypassed.
Rather than Arm/Bypass the whole PLEG, you could also add an OnVacation term to some of your Conditions. OnVacation could be a Condition that includes absolute Schedules and/or a VirtualSwitch.
VirtualSwitch is a plugin that creates a device that looks, in Vera’s UI, like a normal Z-Wave switch but has no hardware component. It can be turned on or off through the UI buttons and by using actions from scenes or other plugins. They are very useful for indicating various states like Home/Away, VacationMode, etc.
You can install it from the mios app store: Virtual Switch
