First Screenshot of UI5 (Vera2)
Use the official link to upgrade posted here:
http://forum.micasaverde.com/index.php/topic,8620.0.html
see screenshot attached! 8)
UI5 runnnig on Vera2!
What is the firmware version number?
JOD.
You are running the latest version: 1.5.201.
The old functionality are still working?
Great first UI5 in Switzerland!!!
[quote=“chixxi, post:1, topic:169731”]see screenshot attached! 8)
UI5 runnnig on Vera2![/quote]
All Switches, Dimmable lights, Scenes (only tested simple ones) seem to be working. But of course I had no time to test everything!
do you have the download link?
thanks!
I have the Link from here:
THIS IS NO OFFICIAL RELEASE, I DON’T KNOW WHERE THE LINK IS FROM! DO THE UPDATE COMPLETELY ON YOUR OWN RISK!
I CAN NOT PROVIDE PROFESSIONAL HELP.
http://forum.micasaverde.com/index.php/topic,8589.msg55339.html#msg55339
I will advice against downloading any firmware until MCV makes an announcement. The Vera3 link may work, but you have to understand Vera3 is different hardware from Vera2. It uses a different cpu and kernel!
  • Garrett
I did the upgrade on Vera 2, but I have problems!!
I use the the link, but now i have an hybrid, new structure but old layout!!
Chixxi you don’t have this problem?
just had to click reload in my browser. maybe empty your cache…
GREAT TRICKS!!!
Mine did that too (a weird hybrid) until I closed and reopened the web interface. So far this looks terrific!
This morning first my logitech revue and then my vera got updated, I’ve been waiting for both updates for months, so this is like an early Christmas!
And speaking of Revues the first “App” I noticed in the Vera App store was “Squeezebox Controller” which controls squeezebox servers (which can control music for squeezeboxes and music, pictures, and videos on logitech revues).
If you are going to update your firmware and take the risk, after updating, you must refresh the browser and clear the cache. For firefox this would be ctrl-f5. Or you can clear out the cache in the browser settings.
  • Garrett
ok. I really have no problems. but only try this if it would basically not matter to you if your vera bricks completely! garrett is right!
i can still confirm scenes with luup running. functioning 3in1 motion light temperature sensors. functioning schedules, working google weather plugin installed from new appstore, functioning (old looking) smart phone interface (preinstalled before update), ability to create new working scenes…
no I am going out for a beer. happy weekend! :stuck_out_tongue:
Also bear in mind you will likely also lose SQ remote compatibility and possibly some of the other CP apps too!?
the sqblaster plugin is available in the appstore. i have installed it, but not tested. no time left…
EDIT: I can confirm sqblaster plugin sending commands by scenes working with sony tv without having to reload the config files!
EDIT: The SQ Remote App (on the iPhone) does not support the new Firmware!
SQRemote uses Vera’s uPnP interface, doesn’t it (I’m not sure but it seems logical)? I would expect that to remain unchanged.
Besides SQRemote and iVera compatibility, I’d like to know about any custom devices (virtual switches, etc) working or not working in UI5
Changes were made that requires updating the plugins. Not all plugins will work or function correctly.
  • Garrett
Any ideas what plugins will not work?
After upgrade I connect correctly. Now I cannot more connect. It seems problem by fwd.mios.com.
Do you have this problem?
I am here: http://maps.google.com/maps?ll=46.015714,8.952514
