Just installed the new UI5 408 firmware on my VERA 2.
Now VERA will do a poll automatically to the Kwikset lock after each change. It solved the problem of incorrect status being reported on the dashboard.
Astrolow-
Assume that were talking about PIN changes? Are there both the daily and the weekly lock schedules supported?
Don
Astrology is referring to the problem of commanding an unlock from the GUI, the lock reacting, but the status in the GUI not changing.
Now Vera will command an unlock, wait a bit, and them poll to serve if the unlock worked.
(and the same goes for the reverse lock operation)
I’m waiting to make an assessment of when to go to UI5. Since I use Vera in rental property I need the door lock to work flawlessly. I was hoping that someone could describe the current functionality of the Kwikset door locks under UI5 (1.5.408) (I’m not expecting an essay… do both the daily and weekly lock functions work?)
Don
