I tried to load firmware version 1.0.491, counter did not count during the load, pressed F5 to refresh the browser now I have a brick.
Vera will not reset, it will not accept a flash firmware either. Power LED flashes twice with a slight pause in between flashes. I can still connect via wireless but my browser will not find Vera even using the IP address.
Any ideas on how to bring her back to life?
Did you wait 15 min as suggested on the upgrade screen before refresh?
No, 2 minutes only. I know its my bad but now I need to fix this.
these boxes are recoverable …
call Tech support the will guide you …
Or if someone has the restore proceedure…
Problem solved with the help from a great support team! Looks like the DHCP setting I had was conflicting with my DSL router on my network. Best to keep the default DHCP IP address even if you are not using the option.
Yes aren’t these guys at Micasa Great… They really know how to troubleshoot. A++
