Firmware 1.5.408 --> 1.5.622
Hi All,
Bear with me as I have only had my vera lite for a week and having a love (all the possibilities) hate (the aeon HEM monitor) relationship with it at the moment.
Today when logging onto the web interface today it says there is an update to 1.5.622 and should click on the link to upgrade.
However reading through the forums its suggested not to upgrade through the link. Was this due to the firmware not being available directly to the units or that it can cause problems using this process?
Is the suggetsted route to use this link Upgrade
Brett
The upgrade via your Vera should work. What you maybe reading was the initial beta release which is now released as the current released firmware. However whilst it was a beta release that link wont upgrade and subsequently after general release people were utilising old links which were redundant and hence not functional.
The generic site for Vera 2, 3 and lite is below.
http://cpui5.mios.com/firmware/
… Once the correct platform is select, Vera lite in your case, it will display the link for that model as you have in your post. So, yes you can use that link but technical both should work.
Thanks for the reply… ;D
Are there release notes for this update anywhere? Has anyone had any issues post this update?
http://wiki.micasaverde.com/index.php/Release_Notes
Found by Googling “Vera firmware release notes”.
