I am starting to work on getting my Altsteon stuff put on the marketplace to make it a bit less painful to install. When I uploaded a few files, I accidently put them in the wrong role. There didn’t seem to be a way to change the role once it was uploaded, so I figured I could delete them and add them again later. Problem is, once I have deleted them, any attempts to upload a new version results in a “Filename already used.” error.
Anybody else seen this? Any suggestions how to work around it? (Other than renaming the file.
Unfortunately, it was an initial import so there was nothing to revert to, and I have already done it. Is there anyone that I can contact about getting the database fixed up so I can import these other files?
Also, is mantis the location to file bugs for apps.mios? Or is there are different one? It seems that not being able to redefine a file’s role is a bug. I realize that in general you wouldn’t do that, but if you fat finger something (or are just not paying attention) you are out of luck.
I just ran through the list of files I had previously had problems with. It looks like D_InsteonEzFlora.xml is the only one that I can’t upload. All the others seem to have gotten cleared out correctly.
This is a really ridiculous problem which should be fixed fast!I took a day of in the hope of being able to finish my xbmc plugin, now I am fooling around with problems like this. I know it’s not hard to get around this problem, but it is stupid that such a problem even exists.
Can you reset the file I_XBMC.xml in the xbmc plugin I am working on so that I can re-uplaod this file?
