Fibraro Universal Sensor Power supply
Can anyone recommend a mains powered transformer suitable for the above, available in the UK.
Mike
Don’t you have anything laying arround , like an old phone charger?
I got 1 running on an old Iphone charger and one on an even older nokia charger.
Cor
of course, but ts not ideal, i would like to install in a small ip67 enclosure for external use.
I don’t think you can find them smaller as an Iphone charger.
Hook/srew/solder the power directly on the 2 metal outlets with some heatshrink and you’re done.
If that’s too big , try this:
[url=http://www.dx.com/p/hzdz-switching-power-supply-module-green-5v-700ma-271900#.VZ2HjPntmko]HZDZ 3-Digit Red LED Digital Voltage Meter (DC 4.5V~30.0V) - Free shipping - DealExtreme
Cor
Thanks for that, will 5v really cut it, I thought 9v was the minimum
And you’re absolutely right , it says on the specs 9v … my bad :-X
Although I am pretty sure I have hooked up a 5v power supply on one of them … anyway . maybe this?:
[url=http://www.dx.com/p/isolated-switching-power-supply-module-green-12v-400ma-237434#.VaKUt_ntmko]Professional 15A Practical Waterproof In Line Fuse Holder Tool Kits (Size-M) - Free shipping - DealExtreme
Cor
thanks Cor, looks perfect, now where did i put that soldering iron !
M
