Fibaro's "in row"
hey there.
i have small issue
i have a ceiling fan with lamps (turkish style thing) … but only one switched Power line is going there.
we never switch of the fan itself … so the wall switch turns the fan on and off.
the lamps are switched with the rope-switch on the fan itself.
my idea is to have a Fibaro switch somewhere to switch the “main power” and behind that another fibaro to switch the lights
the problem i see is the vera may moaming about the 2nd switch become offline all the time if the fan is turned off then.
is there a way to force vera to just assume the 2nd swich is battery powerd instead … so the vera will wait for check and changes ?
or any other suggestions ?
i was thinking to just put a dual switch inside the fan itself … but i do not have permanent power there … that may be a problem as well.
A dual switch in the fan seems like the best solution. Just leave the wall switch on all the time, or even remove it and permanently connect the wiring (depending on where you are, this may violate electrical code)
[quote=“nullx8, post:1, topic:176850”]my idea is to have a Fibaro switch somewhere to switch the “main power” and behind that another fibaro to switch the lights
the problem i see is the vera may moaming about the 2nd switch become offline all the time if the fan is turned off then.[/quote]
You’re right, that is not going to work. Taking nodes out of the Z-Wave mesh (by depriving them of power, in this case) is going to make your whole mesh unreliable.
I know of no hack to make Vera think that a node is battery-operated. Even if there was, battery-operated Z-Wave devices wake up on a regular schedule (say, hourly) to check in, and your proposed configuration can’t guarantee that. Vera will decide one night while it is doing an automatic heal that your switch has gone AWOL.
yeah right, i forgot about the healing …
well i think i have set that not to be done automatic anyway.
but i notice a large drawback in performance since i have 1 offline switch out for repairs (even no other module use it as a neigbor) the vera gets VERY slow if a device is not reacting as expected.
my main reason for this idea was to keep the switch “intact” … so i avoid the rope-switches beeing used (they are this 3 step type switches)
well i’ll go with a dual Fibaro then … they also fit nicely under the cover) and do some soldering to make the rope-switches just do one on/off step,
i dont need the speed selection anyway (too slow = no airflow, too fast makes the ceiling vibrate … so its anyway just one speed)
was thinking (if i use permanent power) to maybe use a dimmer and a switch … (add some coolness to the light) … but thats not very cost efficient.
and with a fibaro on the lights i can combine that with the TV backlight (it has no physical switch atm, and drives my wife crazy) :wink:
