I have two Fibaro wall plugs connected to my Vera Lite, but they still don’t work properly.
If i install the fibaro plugs in range of 2/3 meters of the controller they connect and stay connected just fine.
However, if i move the plug away from the controller they have issues reconnecting sometimes.
Mostly if there is a power failure or if i unplug the Fibaro plug and plug it back in.
Then i get the following error codes in Vera Lite:
Cannot contact device, error code: 1...
ERROR: Unable to get any information on node
The only solution i could find is to exclude the device from vera lite and include it again.
Anyone else facing this issue and managed to solve it?
