Fibaro unwanted child devices created
Dear all,
I am using Vera 3 latest frimware verson and have several Fibaro devices connected (about 40) although they all seem to be compliant I have some strange things goin on.
1- A fibaro wall socket plug, normally on-off only (and powerrusage measurement) started to create 12 child devices automatically in the Vera. I have several of these plugs but this is the only one showing strange behaviour. It also created child devices with same numbers sometimes . This socket is not changing state I locked it (homewave app) so nobody can change its state (it is only a socket for vacation purposes).
2- A dimmer FGD-211 also started to create child devices (6 devices) This dimmer; I am using the S2 switch to start scene’s however I have done that with other dimmers aswell same brand same version
3- I have two binairy Universal switches and each have 4 temp sensors on them and two other binairy inputs. Vera creates these child devices correctly, however after a week I looked and i noticice that both devices created 4 general I/O child devices each and both also 2 motion detectors. Also sometimes Vera states note not configured and I press configure node now and everything runs ok untill 2 days later I can do it again. This device does not look compatible with Vera.
Anybody with same experiences and or suggestions to improve this or is my vera on the run. I will try to disconnect the devices and re-connect them but I don’t think it will help.
Try taking one of these devices and exclude it from Vera and re-include it. See if it stops creating new devices. If it still happens, you may want to put in a trouble ticket in with MCV.
  • Garrett
