I have a Fibaro universal sensor with 4 temp sensors reading the temperatures in 4 different rooms. I can assign each temp sensor to a particular room but periodically everything is reset to the default room I installed the sensor under. This happens perhaps once a day or whenever the system reloads /refreshes etc. I can’t figure out how to lock the allocations. Can anyone offer a solution?
(ps…as mentioned under another topic by others, since the latest release of f/w, the trigger inputs on the universal sensor have stopped working. The 1-wire temp functionality works fine though)
