Fibaro universal sensor FGBS-001
Hi!
I’ve Just noticed that one of four temp sensors freezes on the same temp, when this happend in Ui5 i only hit the ‘configure node’ botton and the sensor came back to life, but now i am on Ui7 and this is not an option anymore.
Any idea anyone?
Here is an update in case someone are having the same issue.
I hit the configure node botton severel times until the fibaro with the 2 binary inputs and 4 temp sensor came back on the Ui7. all Devices had now default names and new #iD, so I had to rename them and change every scene, pleg etc where i used the different devices. The binary inputs also worked as before with NO contacts.
Noticed today that one of the four sensors was freezing on the same temp again, according to datamine this happend yesterday so I restored a bacup from the day before. The temperature changed but it still freezes on a lower temp… Anyone else having the same problem or is it just me?
I have the Same problem.
Dit jou manage to get it working already.
Same problem here…
any tips to resolve this ?
Only thing for me is to clic on “configure node” buton ( and it doesn’t work always) but one or two week after the temperature indicator freeze again…
(FGBS-001 + DS18B20)
Just a lucky guess: maybe replace the temp sensor which is causing problems with another one?
Am very interested in getting this for a hot water cylinder that almost blew up recently (!). Would you have any guidance on a power supply for the universal sensor and best practice on how to connect to DS18B20? Have seen a good article Stylish and environmental smart home design & build but I am a complete novice.
