Fibaro universal sensor - configuring
Hi, one of my four temp sensor says “configuring” all the time on the UI, it has been like this for a while now but the sensor is working, it all started when the sensor stopped responding and i did a “configure node right now” on the child device. I ment to do this on the parent device, and when i did the sensor started working againg properly, but now it always has a blue light and says configuring.
appreciate the input
On the Advanced tab of the problem child, look for the variable Configured. It is probably showing some negative number. Set it to 0, close the device block and click Vera’s Save/Reload button.
Thank you @RexBeckett
